[Guide] Homatics Box R 4k Plus CoreELEC installation, configuration and modding
Compatible Devices
  • Homatics Box R 4k Plus
  • DuneHD Homatics Box R 4k Plus
  • Nokia 8010
  • RockTek G2
Requirements
  • Android TV firmware v5310 for Homatics or v5554 for Nokia 8010 (otherwise DolbyVision won’t work )
  • USB Stick / USB SSD (whatever USB Storage you have available )
  • Balena Etcher → balenaEtcher - Flash OS images to SD cards & USB drives (this is used to flash CoreELEC image onto the USB Storage )
  • CoreELEC 20 amlogic-ne GENERIC image → CoreELEC 20-NE ( This is considered the stable version ,based on Kodi Nexus )
  • CoreELEC 21 amlogic-ne GENERIC image → CoreELEC 21-NE (this is the bleeding edge version ,based on Kodi Omega which is still in Alpha stage ,so don’t complain if it’s buggy ).
  • Toothpick or any other tool that you can use with the device’s reset pin hole
  • Enable CEC on your TV (this is optional,but i recommend to enable CEC so you can do the CoreELEC’s initial setup easily ,using the TV’s remote control )
Preparing Installation Drive
1. Connect the USB Storage to your PC and open Balena Etcher
2. Select the CoreELEC’s image file (eg. CoreELEC-Amlogic-ne.aarch64-20.3-Nexus_nightly_20230729-Generic.img.gz )
3. Select the USB Storage that you want to use, proceed with the installation and make sure that it will complete successfully .
4. Your USB drive will now have two partitions ,COREELEC and STORAGE
5. Open the COREELEC partition ,navigate to “device_trees” folder
6. Copy sc2_s905x4_sei_smb_280.dtb file to COREELEC root and rename it dtb.img
7. Safely remove the USB drive from your PC
[CENTER]CoreELEC Installation[/CENTER]
1. Insert the USB drive in the Homatics’s USB port (both USB3 and USB2 should be ok)
2. There are two ways to reboot/boot the device into UPGRADE MODE ,one it’s directly from Android ,using and ADB command and the other is by using the RESET BUTTON .
a) ADB Method (make sure ADB Debug is enabled and working )
Run the following command :
adb reboot update
b) Reset Button Method
  • PowerOFF the device and remove the DC power connector (or remove the power adapter from the wall socket )
  • Press and keep pressing the reset button ,then Power ON the device while keep pressing the reset button until the CoreELEC screen will appear .
  • Release the Reset Button
3. At this point ,if everything went well ,CoreELEC should be up and running ,so just proceed with the initial setup .
[CENTER]Remote Control Configuration[/CENTER]
Homatics Bluetooth remote pairing
  1. Go to Settings → CoreELEC Configuration → Bluetooth
  2. On the Homatics remote press BACK + HOME for seconds (this will put the remote in pairing mode )
  3. Check if your remote is showing in CoreELEC’s Bluetooth screen ( usually is named B21,B25 ,depending on your model )
  4. Select the remote and press PAIR
  5. Check if CoreELEC is responding to the remote commands
NOTE : If the remote is not working even if the pairing was successful ,try to re-pair it ( BACK+HOME combo) or reboot the device.
NOTE 2 : If the remote stop working after a reboot/shutdown ,try to re-pair the remote (BACK+HOME).
Unfortunately this is a known issue and you will most likely face it when you reboot from CoreELEC to Android and then back to CoreELEC .
Currently there’s no fix or workaround .
If you want to use the IR (infrared) protocol of your DuneHD ,you will need a remote.conf file ,compatible with your remote .
Thankfully ,another user shared such a configuration file ,so you won’t have to create one yourself .
Copy the “remote.conf” file to /storage/.config folder and reboot the device.
To customize the remote buttons i recommend using the Keymap Editor add-on ,from Kodi Repository → Program Add-ons section .
Link to DuneHD remote.conf
Nokia 8010 IR remote protocol with meson-ir driver
In the links bellow you can find the KEYMAP and the instructions how to use your Nokia 8010 infrared remote protocol with CoreELEC and meson-ir.
NOTE: that the second link has a more complete configuration file ,so i recommend using that one .
Link 1 (more detailed instructions)
Link 2 (fully working KEYMAP)
[CENTER]Troubleshooting[/CENTER]
  • You have followed all the steps from this guide but CoreELEC is still not booting.
  1. Try a different USB port .
  2. Double check that you have used the correct DTB and you renamed it correctly .
  3. If you are using an USB HUB,try removing it and attach the USB drive directly to the USB port.
  4. If the above solution aren’t working ,then you should try another USB Drive (usb stick,ssd,etc),there were several reports about certain USB sticks or USB-SATA adapters not working correctly either this device ,even if they are fully working on a PC/Laptop or other devices.
  • Original Bluetooth Remote (B21) not working after a reboot .
    Solution : Press Back + Home buttons for 5 seconds and your remote should be working again
  • CoreELEC it’s not working after resuming from stand-by .
    Solution : Stand-by is not officially supported on these devices ,so i recommend you to avoid using it.
  • Can’t PowerON the device with the remote .
    Cause : Some of these devices don’t have an IR receiver ,so if you PowerOFF your device ,you won’t be able to power it ON with a Bluetooth remote .
    Solution : Either use an IR dongle (eg. FLIRC) or avoid a complete shutdown of the device.
  • DolbyVision is not working
  1. Your Android TV firmware might be incompatible with your current CoreELEC version.
  2. You might need to enable DolbyVision in Android TV before using CoreELEC (eg. You never used Android TV after you bought the device and you went straight to CoreELEC installation )
  3. Add dovi.ko file to root
[CENTER]FAQS[/CENTER]
Q: Is it possible to install CoreELEC on the device’s internal storage ?
A: No,do to the nature of how CoreELEC works on this device ,it is not possible (and probably never will) to install CoreELEC on the internal storage .
However ,it is possible to use a sort of hybrid installation that will let you use the internal storage for the “STORAGE” partition ,but keep in mind that this solution is not supported by the CoreELEC Team,so use it on your own risk and don’t complain if you are having issues or data loss.
Here’s the solution ( thx @vpeter )-> Homatics Box R 4K Plus - #278
Q: Why i can’t PowerON my Nokia 8010 device with the remote control ? Is there a fix for this ?
A: Unfortunately the bootloader doesn’t have the required IR codes to wake up the device with the Nokia remote control.
Q: Is it possible to customize the device’s LEDS light?
A: While there’s no CoreELEC’s built-in option for that ,there’s a separate add-on that does that .
Homatics LEDs add-on → Homatics LEDs addon
Q: I would like to reboot to AndroidTV by using a remote control button ,is it possible to assign that function to a remote button?
A: You can use this example ( thx again @vpeter ) to accomplish that .
Remember ,that’s only an example ,so you might need to adjust it for your needs.
Reboot to Android with remote control button
Q: Wont boot via 3.0 port
A: Only certain models of flash drives boot via the 3.0 port (change drives as needed)
MODDING
Disclaimer: Modding your device may void the warranty, so use them on your own risk.The mod author,CoreELEC Team or anyone else but yourself can’t be hold responsibile for eventual damage caused to your device/s.
CREDITS : All credits go to their respective owners .
Great job, all I would add to FAQ is that during CoreELEC install the tar unzip can take 2 mins or more depending on size/type of usb storage, it’s easy to think the procedure has failed/frozen. Same for nightlies updates.
Should the remote be working after first booting CoreElec or do I have to connect a keyboard to pair it? Just pressing home and back until the LED blinks does not do the trick. Rebooted into Android and back to CoreElec but remote not connecting whatsoever. I do have the DuneHD version and the remote is connected as R25 in Android if that makes any difference.
Edit: I connected a keyboard to pair the remote but the remote didn’t work after pairing. Repaired several times without success. I then tried rebooting (I didnt unpair before) and now the remote suddenly works.
How to update the android tv firmware?
ill incorporate that in my guide update (:
but basically you have to go into your power menu and select reboot to emmc than inside android just update as every other android tv
Idk how android tv works its my first atv box tbh.
I hope i will receive my box tomorrow.
Thnx for the info
Compatible Devices:
Supported devices by CoreElec Team: List
Details and Pictures of the devices: AVS Forum Thread
Requirements
  • Android TV v5310 or higher for working Dolby Vision
    (see FAQ for upgrade instructions)
  • fast USB Stick / USB SSD
    ( this will be the main boot drive ) i reccomend: Samsungs FIT Plus USB 3.1
  • flashing tool like Balena Etcher or Rufus (Win only)
    (This is considered the stable version ,based on Kodi Nexus )
  • Sim Tray Tool / Toothpick
    (or any other tool that you can use with the device’s reset pin hole)
  1. Connect the USB Storage to your PC and open flashing tool (eg Balena Etcher)
  3. Select the USB Storage that you want to use, proceed with the installation.
  4. Verify that the flashing process was successful
    (Balena Etcher will do that for you in the Validation process [green bar])
    1. Your USB drive will now have two partitions ,COREELEC and STORAGE
    1. Open the COREELEC partition ,navigate to device_trees folder
    1. Copy sc2_s905x4_sei_smb_280.dtb file to COREELEC root and rename it dtb.img .
    1. Safely remove the USB drive from your PC
  1. Insert the USB drive in the Homatics’s USB3 port (blue)
    (USB3 is faster / USB2 had Suspend )
  2. reboot/boot the device into UPGRADE MODE
Simple Method / Restbotton
  • Press and keep pressing the reset button,
    (hold even if menu / fastboot is shown).
  • Release the Reset Button (if you see the CoreElec boot screen)
Advnaced Method / ADB (only from AndroidTV)
  • enable ADB in Android
  • Run the reboot command with update parameter
  • adb reboot update
  • wait until you see CoreElec boot screen
  1. follow the initial CoreELEC on-screen setup
    (For working Remote see FAQ / CEC requirements )
Troubleshooting :
You have followed all the steps from this guide but CoreELEC is still not working.
Boot issues
  1. Try USB2 port.
  2. Double check that you have used the correct DTB and you renamed it correctly.
    (see Requirements Step 2.)
  3. If you are using an USB HUB: try removing it and attach the USB drive directly to the USB port.
  4. try another USB Drive (usb stick,ssd,etc)
(some especially old or often reformatted USB sticks have issues with their controllers)
[some vendors offer reset tools with which you can deep reset/reformat the usb stick and remove any kind of write protection or other settings but since its a controller reslash i wont link to it use google :wink: ]
Known Problems
Original Bluetooth Remote (B21) not working after a reboot:
CoreELEC it’s not working after resuming from stand-by.
Stand-by is not officially supported on these devices,so i recommend you to avoid using it.
Cause: Some of these devices don’t have an IR receiver ,so if you PowerOFF your device ,you won’t be able to power it ON with a Bluetooth remote .
Solution: Either use an IR dongle (eg. FLIRC) or avoid a complete shutdown of the device.
(i use a remote power plug for example tasmota with home assistant or use a wireless plug)
Possibile Cause:
    (see Requirements)
  3. you need to enable DolbyVision support on your TV / Projector either in Settings or via Firmware upgrade
FAQS
Q1: Is it possible to install CoreELEC on the device’s internal storage ?
Here’s the solution ( thx @vpeter )-> Homatics Box R 4K Plus - #278 by vpeter
Q2: Is it possible to customize the device’s LEDS light?
Q3: I would like to reboot to AndroidTV by using a remote control button ,is it possible to assign that function to a remote button?
Reboot to Android with remote control button → Physical button execute script - #6 by vpeter
  • Homatics Bluetooth remote pairing
If you want to use the IR (infrared) protocol of your DuneHD ,you will need a “remote.conf” file ,compatible with your remote .
Copy the “remote.conf” file to “/storage/.config” folder and reboot the device.
To customize the remote buttons i recommend using the “Keymap Editor” add-on ,from Kodi Repository → Program Add-ons section .
Link to DuneHD remote.conf → Homatics Box R 4K Plus - #620 by aszi
  • Nokia 8010 IR remote protocol with meson-ir driver
NOTE that the second link has a more complete configuration file ,so i recommend using that one .
Link 1 (more detailed instructions) → Homatics Box R 4K Plus - #985 by frodo19
Link 2 (fully working KEYMAP) → Homatics Box R 4K Plus - #1077 by Vex
Q4: My Remote is not Working
A: For Homatics Blutooth remote try to re-pair it
(pres & hold BACK+HOME until the green LED is blinking fast - when it stops blinking its paired again and should work)
For remote.conf KeyMaps see:
Nokia: Homatics Box R 4K Plus - #1077
Dune HD: Homatics Box R 4K Plus - #620
Homatics: Homatics Box R 4K Plus - #960
Q5: I have a distorted Screen after Boot
A: Always boot the Homatics box after AVR / TV
If you see something like the Picture below you HDMI handshare probably failed.
Make sure your AVR / TV are properly started before starting the Homatics box!
Q6: How to upgrade my Firmware (eg for Dolby Vision)
A: Upgrade the Android TV version.
  1. Boot as usual and navigate to your Power menu
  2. Select reboot to emmc
  3. wait until Android TV is booted.
  4. upgrade like any other Android TV/Device
    • login to android
    • navigate to settings
    • check for update & install
      if there is no update available it was suggested to write homatics support
I still need help and have read all the Guides and FAQ thoroughly
You may polity ask your Question in the official Support Thread
Remember:
  • it is a Project run and build by Volunteers
  • Prior to posting an error: Read how to post logs
  • try to search the Thread if your Question may be awnserd before
Thank you all<3
@pretoriano80 for the Original Guide
@vpeter for the permission to write this as a Wiki Template
and all the other supporting this project
CREDITS : All credits go to their respective owners.
//edits:
20230805 formatting & fixes
One table of supported devices is also this: Homatics/Dune/Nokia/Rocktek Dolby Vision
@DS_DV why not adding only the missing pieces instead of a redacted and updated full guide ?
IMHO it’s a bit confusing and looks a bit like highjacking. :))
@vpeter thats little outdated now… nokia has ir port too, homatics and homatics dune new versions not have av port anymore…
i promised to update and post my obsidian notes this weekend.
You “rushed” me with your posting.
So i saw no sense in just making another guide.
Which is the reason why i tried to add and incorporate my notes and the things i remembered from the thread.
If you don’t like that i based it on your post i can write my own (but as i said i see no reason i redundant work).
I especially tried not to delete anything so i don’t know where sth should be “redacted” ? O.o
Are you referring to spoilers ? O.o
They make the thread less cluttered and improve the UX for new users since they are not slain by a wall of text and can quickly navigate.
To be honest for my taste this draft still looks pretty clutter and not very user-friendly.
If i find some time ill work on that.
If the CoreElec team has some whishes (like if it should stay all in one post or for Example plit parts) ill incorporate that ofc.
At least my goal with this was to make sth which can replace the first post of the Support thread so new users have a better UX and dont have to ask that many questions (or can easily be linked to)
It is based on information we had at that time. We were mostly interested in LED type, PCB revision used and Amlogic dt-id used.
@DS_DV what i meant is that it would have been easier for me to add the extra info from your guide to OP,if it wasn’t the complete guide ,but only the pieces that are missing from my guide .
However ,there’s no problem for me,as long as it helps people to start the CoreELEC journey without asking the same things over and over again .
An if someone fails to follow such a guide ,then it’s probably better to start with the basics before installing CE. :smiley:
If you have no objections we’ll incorporate parts of the guide in our wiki.
No problem ,it would be nice if the Wiki could cover some of the infos from here.
sure that was the whole idea of it :smiley:
What coreelec version i meed for dolby vision Nexus or Omega?
Wrong question !
You should ask “which Android TV firmware is required for DolbyVision support on CE?”. :slight_smile:
Your device’s Android TV firmware must be v.5310 or higher ,just like i wrote in this guide .
With v5310 you will get DolbyVision in both CE20 and C21.
With firmwares versions lower than v5310 ,only certain (older) CE21-NE builds will have working DolbyVision .
