I just discovered CE and happy to see the focus is on AML devices (thanks for your hardwork !!)
I’m currently using LE 8.2.2.3 on Minix U9H with Plex and PKC plugin. So far, all is working pretty fine, with the features that I need:
4k HDR content playing nicely and smoothly and with autoswitch
media content hosted on 2 NAS, using SMB
TrueHD / Atmos / DTS:X
External subtitles perfectly integrated
Logitech Harmony Remote (i’m using windows profile)
I would like to give a try to Kodi 18 CE and I want to know if there are any important drawback I should know before switching for good. So the best way is for me to try it of course ! But I would like to confirm the below 2 points with the community:
My current LE is installed on internal memory of Minix U9H, can I install CE on SD card (or USB) and boot on it without trouble or deleting my current LE install ?
Should i install: CoreELEC-S912.arm-8.95.7-S912.img.gz or 8.99.1.1 ?
Yes
8.99.1.1 is our latest release so go with this, there is an issue with dvb adapters on this release but it has been fixed in our nightly if you require this.
Thank you for your quick reply, I will give a try to 8.99.1.1
Is there any important known bug or issue I should know about for Minix U9 / S912 and CE latest build ?
So i finish my tests and so far it seems to work pretty well, a part from 2 bugs
Cannot use bluetooth (the list that shows all available devices keeps refreshing every half seconds). this is a blocking point for me as it prevents me from using harmony remote
The skins reload itself after sometimes of usage, especially when I browse various settings (not sure if this is a skin issue or CE issue)
Anyway, BIG thanks to all devs for all your hard work and making Kodi working on AML !
well no, I didnt do that…
However, and as strange as it seems, it’s now working fine. I didnt do anything in particular tbh, simply checking the bluetooth version via ssh. i the went on doing other things, leaving the box running. Then when I came back (Several hours after) the bluetooth was stable and I could select my remote and connect to it.
Now everything is fine so far !
I didnt select any device tree when installing CE, so I was using the one by default in 8.99.1.2
Is there a way I can “update” by using the correct one ? Or should I reinstall everything ? (so far everything is installed and properly configured, I’d rather not do a blank installation again…
Put the SD card into your computer, and copy over the correct DTB from the device trees folder to the root of the SD card, then rename it to dtb.img. You should really read the installation instructions before posting questions that have been answered countless times.
@TheCoolest he already said hes running from internal.
@plouf
As @TheCoolest says you should really read the install guide before installing, its imperative that you install the U9H specific DTB as there is a bunch of things that will not work without it.
Well, I did say LE was on internal memory but CE is on SD card and working fine so far.
I didn’t put the right device tree before my setup (my bad for sure !)
My question was: can i put the right device tree at the root of my SD card now that everything is working fine ? Or should I do another fresh install and re configure everything in Kodi ?
