Looking for users with no working WiFi or BT
If they disappear again go back to main window in Kodi and try to execute systemctl restart connman. What a bit and check again in CE settings if the networks back again. If yes please enable kodi debug logging and do it again. Then upload kodi debug files: How to post debug logs
X96 Mini users with SDIO_ID=3030:3030:
Please setup 19.1_Matrix_rc2 stable first!
If Matrix is running please update with this tar:
CoreELEC-Amlogic-ng.arm-19.1-Matrix_devel_20210412115501.tar
It include a updated SSV6XXX_SDIO driver and maybe works.
Please post a log by:
dmesg | paste
Would there be any chance of this one becoming operational under CE?
Or is it just not possible/too much fuzz/else ?
If i can assist with any other info needed, pls let me know.
Thanks.
As u wrote. Connections empty, but with command: systemctl restart connman everything works flawlessly. Here are debug logs:
Before command (not working): http://ix.io/2VQQ
After command (working): http://ix.io/2VQR
And they stay online? Also after a hour?
So it happen that sometimes the WLAN are not found after a reboot or are they visible and disappear?
After a hour seems to be everything still ok.
  • if the list doesnt load after boot, …after 1 min, 5 min, 1 hour, list is still empty.
  • but if the list loads after boot (or after systemctl restart connman command), it still holds. Everything seems to be ok.
btw I have 4/32GB version, my friend has 4/64GB version - same issues
@Dzimmi please update with this image:
CoreELEC-Amlogic-ng.arm-19.1-Matrix_devel_20210412202424.tar
Please reboot multiple times and check if it is working now.
Please post also the output of:
journalctl -u connman
one time if it does not work, and one time if it worked and the wlans are visible.
EDIT:
@Dzimmi I had a typo in the test image. Just delete it and download this image for the tests:
CoreELEC-Amlogic-ng.arm-19.1-Matrix_devel_20210412203548.tar
EDIT2:
udevadm info /sys/bus/sdio/devices/*
first image, works all 10/10 restarts/shutdowns, Log is here: http://ix.io/2VRo
Booting is maybe about 20 seconds slower.
Now i will try new image.
second tar file:
5x doesnt work
http://ix.io/2VRu
P: /devices/platform/ffe03000.sdio/mmc_host/sdio/sdio:0001/sdio:0001:1
L: 0
E: DEVPATH=/devices/platform/ffe03000.sdio/mmc_host/sdio/sdio:0001/sdio:0001:1
E: DRIVER=ar6k_wlan
E: SDIO_CLASS=00
E: SDIO_ID=0271:050A
E: MODALIAS=sdio:c00v0271d050A
E: SUBSYSTEM=sdio
E: USEC_INITIALIZED=6593443
E: SYSTEMD_WANTS=qca-firmware-aml.service
E: TAGS=:systemd:
E: CURRENT_TAGS=:systemd:
1x works
http://ix.io/2VRy
L: 0
E: DRIVER=ar6k_wlan
E: SDIO_CLASS=00
E: SUBSYSTEM=sdio
E: USEC_INITIALIZED=6587770
E: TAGS=:systemd:
Thank you, i think there is something still not working. Will check it tomorrow.
@Dzimmi
please test this image:
https://mega.nz/file/CSZwybbB#RgQsKQwxKY59HoCe2LCXDv7hD9eHqA3WdJWvj23JJBo
please try some reboot again and check WLAN, thank you.
6x boots, everything seems to be fine. It is booting faster now. Friend’s device same :).
Logs:
http://ix.io/2VRT
L: 0
E: DRIVER=ar6k_wlan
E: SDIO_CLASS=00
E: SUBSYSTEM=sdio
E: USEC_INITIALIZED=6576876
E: TAGS=:systemd:
Please try it 1-2 days and report back.
If it works it can go into nightlies, thank you.
Sure. Thank you for your fast and brilliant help!
Hello and thank you @Portisch for your help.
In new x96 mini i first install 19.1_Matrix_rc2 stable and then update with [CoreELEC-Amlogic-ng.arm-19.1-Matrix_devel_20210412115501.tar], and i´m allready can reboot the box :slight_smile:
remains No Bluetooth and no WiFi.
P: /devices/platform/d0070000.sdio/mmc_host/sdio/sdio:0001/sdio:0001:1
L: 0
E: DEVPATH=/devices/platform/d0070000.sdio/mmc_host/sdio/sdio:0001/sdio:0001:1
E: SDIO_CLASS=07
E: SDIO_ID=3030:3030
E: MODALIAS=sdio:c07v3030d3030
E: SUBSYSTEM=sdio
http://ix.io/2VSG
then update with last tar you send to @Dzimmi , and the box are slowly and wont reboot or power off.
Update with the first tar… et voilá … reboot and power off again.
@truztruz please test this image:
CoreELEC-Amlogic-ng.arm-19.1-Matrix_devel_20210413081124.tar
The test image before did not load the driver at all. Now it should load the updated driver and maybe works…
Hint for CoreELEC 19 users:
CE-19 does support mega.nz. Just update easy by SSH:
cd .update
megadl https://mega.nz/file/....
sync
reboot
Hello @Portisch ,
I update, and with this tar i can´t reboot or poweroff, and still without Bluetooth and WiFi…
L: 0
E: DRIVER=SSV6XXX_SDIO
E: SDIO_CLASS=07
E: SUBSYSTEM=sdio
h**p://ix.io/2VV7
thanks for help
not working:
[<ffffff800224bb90>] ssv6xxx_dev_probe+0x1080/0x1a80 [ssv6051]
@Dzimmi please update to this image:
CoreELEC-Amlogic-ng.arm-19.1-Matrix_devel_20210413152421.tar
It should still work after each reboot. Just test if it find wlan every boot, no log required, thank you.
@Portisch thank you for your time, and thank you for help noobs like me.
But when you say “not working”, do you mean this is the end of the line, for the new x96 mini ??
