Looking for users with no working WiFi or BT
As no dev have such device with this 3030:3030 Wifi SoC I would say yes…
Happy to confirm this fix works on my X96 Max plus Q2.
wifi & bluetooth connections both solid after multiple reboots and tests.
Thanks for the continued hard work and support Portisch
Thank you, did you test with this image?
@Portisch Can i send you, one of this new x96 mini, to study and develop.
If yes, please send me private message, with your address.
Yes, using this image, it works flawlessly for working wifi and BT on my X96 Max plus now.
Thanks again
Could support for the RTL8723AS be added as well? Or is this chipset not supported by Linux?
udevadm info /sys/bus/sdio/devices/*
The RTL8723AS should be supported as it’s the same driver like RTL8723BS.
Yeah., that is what I thought, but apparently it’s not working: CE doesn’t show WLAN. I posted the logs earlier in this thread:
@machello please test this CoreELEC 19 Matrix image:
https://mega.nz/file/LToCxI6D#Cj8GKb8uexFOsp_I5zBgwe1TXS4MMIZLrrbL5aTm-8M
Please update to 19-Matrix_rc2 when not already done.
After update please upload also a log:
dmesg | paste
Hi Portisch, CoreELEC-Amlogic-ng.arm-19.1-Matrix_devel_20210412215312.tar works great after 2 days and newest CoreELEC-Amlogic-ng.arm-19.1-Matrix_devel_20210413152421.tar works too (5x restart).
Progress! CE does now show the WLAN configurations options, but it appears not to be scanning for networks: there are no WIFI network in the Connection menu item. Furthermore:
lsmod |grep -i 8723
8723bs 1585152 0
Dmesg:
http://ix.io/2W1P
I tried rebooting, disabling and enabling the wlan menu option, but no luck.
Forgot to add: BT is not working either. But for me that’s not a problem.
I think your device reached EOL:
The chip SoC got removed Dec 31, 2014.
There is no driver out there anymore supporting RTL8723AS.
[post removed…I got it]
Vontar X96 Max plus (S905X3) still no WiFi, don´t work :frowning:
What you expect without any log?
And how can i get log without network? :frowning: I donť understand, sorry :frowning:
You use an ethernet cable and connect it to your router. You don’t need a TV/screen to boot CE and SSH to it.
X96 MAX Plus Q2
CoreELEC-Amlogic-ng.arm-19.1-Matrix_devel_20210413152421.tar is no longer available on the MEGA repository.
Wait for CoreELEC 19.1-Matrix_rc3 to fix wifi and bluetooth bug? When to expect?
https://relkai.coreelec.org/?dir=ce-19
