Had the same issue with 12/08 nightly on Odroid N2+ and C4. Downgraded to 12/7 and all fixed. Saw boot logo and then left top corner screen showed that corner of logo. SSH still worked but uinresponsive. I’ll try and capture logs but I’ve been messing with it on N2 too much, maybe I can get something helpful when I reconnect C4.
There were some changes about get/set kernel data. Maybe something is missed as everything works ok for us.
Please describe more in detail what happen and about the system setup, 4k TV? 1080p?, GUI resolution?
disp_cap or any other display dumps?
We will also need the kodi.log from /storage/.kodi/temp.
Please downgrade to 20211207 and enable debug logging in kodi. Then reboot and backup /storage/.kodi/temp/kodi.log. Then upgrade to 20211208 nightly and after the reboot please backup the kodi log again. Please share both of them.
@telenova @Warchild
@vpeter found a missing part of handling the user disp_cap file.
So if this is the case you’re using then it should starting working again tomorrow with next nightly.
Please check it then, thx.
I had the same problem, it is fixed with nightly 20211210, thank you.
But the distorted boot logo remains (see attached picture) , no big problem, but not nice. A few weeks ago it was ok. When CE has started up, everything is ok. I use GUI with 2160p, because the movie posters are much sharper than with GUI in 1080p.
Not sure which recent nightly it started happening in but I’m on the latest one now and the Player Debug Info is showing everything as being interlaced video. It happens with anything that is played.
EDIT:
I played 3 test files (ISS_4k_HDR10plus_ff.mp4, TravelXP 4K HDR HLG Demo.ts, test_file.mkv) and all showed as interlaced from the Player Debug Info
kodi.old.log (767.1 KB)
From your log it looks like all is correct checking interlace vfmt: null and it should be progressive
So it’s just a bugged visual thing and can be ignored?
Make a screenshot where you see it. From kodi log it’s progressive video.
Check current nightly please if it fixed for you
Yeah its showing p instead of i now. Was it just a visual thing?
Exactly that.
I have a problem whith my s905x3 2gb 100mb Box with both 20 änd 19.4 nightly update:
When I upgrade (rar) with the new Nightlys my LAN dont work
But if I take the Image from the same Nightly it works
If i make a rar update again the LAN dont work
If i change the dtb.img file from the Device Tree then it works
I make a file compare with the dtb.img file from the upgrade and the file in the Device tree there are differences
I test the same on a Odroid N2 and a s905x2 Box there is no Problem
Has enyone the same problems ?
Can you clarify this more in detail? Which files are different?
Hello
Sorry for my bad english
After the update from rar file LAN dont work
If I take the SD card from the box in the cardreader on the PC and delete the dtb.img file and copy
the file from the device tree (sm1_s905x3_2g.dtb) and rename it to dtb.img then it work
But if i make a update again its the same, LAN dont work
And so i make a file compare from the dtb.img file from the upgrade that dont work and the sm1_s905x3_2g.dtb file from the device tree there are differences
I dont know if this is normal
I have the problems since the las thet 2 or 3 updates , i think
Check in CoreELEC settings under hardware/device tree. There has been some changes to support one ethernet adapter.
Can you upload your dtb.img which doesn’t work after update with .tar file?
This is the the dtb.img where LAN dont work
dtb.img (69.2 KB)
Look here X96 max+ revision AI - ICPlus_IP1001 (lan is not working) - #74 by Portisch
And try both settings.
Or just remove file /flash/dtb.xml. Then it should work fine even after update.
I remove the dtb.xml in /flash and now it works !
Thanks for the support
Seriously, there is such a problem when dtb.xml is automatically created and then updated it breaks. I didn’t have a problem with the LAN but after the update the IP1001 option disappeared. Will there be a repair?
