Odroid N2 CoreELEC 9.2.2 not working
Thanks tim
Well I thought it was going to boot.it came up with a system update screen,got to end and rebooted to a black screen :frowning:
Sorted,thanks lads :+1:t2:
Could anyone recommend a good usb emmc writer?
I can recommend only the one I have, which works perfectly for me:
https://www.odroid.co.uk/odroid-accessories?product_id=853
I got my emmc reader/writer with the emmc modul from pollin.de
It was a bundle emmc modul + emmc usb writer/reader
Thanks lads :+1:t2:
just for information. What is the normal process to solve it? Waiting for 9.2.3 or are there intermediate releases?
If you need help in testing please let me know.
I do not want to appear impatient, I just want to prevent this from being lost in the many other postings.
The fix will happen in Nightlies
Don’t ask when it will be fixed as it is a known issue awaiting a fix.
Thank you, I’ll be patient.
Just a little update here guys, CE on odroid is the absolute dogs bollocks! Ticks every single box.
The best Kodi experience going surely?
Made an update to 9.2.3; tvheadend server 4.2 still not working.
Please tell me if you CoreELEC developers want to drop support for TVHeadend. Then I have to look for a better solution. Or do you recommend to use TVHeadend 4.3?
How can I help to solve the problems (I’m not a developer)?
There’s no dropping of support for anything. Tvheadend is widely used with CoreELEC without any problems (or with the problems it usually has). Yours is another problem. There was a problem with usb ports in 9.2.2. If you still have some kind of problem with tuners is not 9.2.2 related. Please open a new topic describing your problem using 9.2.3.
Thank you. It will take some time to decide if it’s worth the effort.
Is it necessary to update the add-ons with the update from 9.2.2 to 9.2.3? I did not notice add-ons showing a need for updates after updating CoreELEC (and Kodi?) to 9.2.3.
Addons should be auto updated if needed. You can enter the add-ons menu, click left and choose check for updates. If you need help open the topic, there are hundreds of users using tvheadend without major problems. I’m one of them.
Meanwhile I opened a new topic:
