I don’t think so no, afaik only an IR remote can be used to power on from a full off state.
Iirc, POWER and VOL buttons on Alexa Remote use IR, everything else are BT.
Possibly on the older Amazon remotes, however on the new voice remote that comes with the 4K stick all the buttons are bluetooth and can be configured inside Kodi.
Interrupt handler delay. We might have to adjust smp affinity.
This has to work. Now I looked in my uart and there is no confirmation that the usr key is setup. But uart will print NEC keycodes if you push some buttons. Can you check uart again and press your NEC keys. Is your remote NEC? Maybe ir-keytable gets the wrong keycode.
@Ray
Spoken too soon. After about 20hr of suspend, got problems as described below
Can’t SSH to it at first, but fixed by toggling Wired Network at CoreELEC Settings.
Managed to upload the logs http://ix.io/1GDs
Haven’t tried your latest build (with sdcard fix)
Regards,
Yeah SD cards are broken with suspend. I will have to look for a solution.
Guys I have problem with remote controller
Ive enabled it using command echo “meson-ir * mecool” > /storage/.config/rc_maps.cfg I cannot power on my n2 device form suspend or shut down.Try this…
This won’t work out of the box. You need to put in some effort.
Sure I understand that but I dont know what file to modify its not so obvious to me
config.ini
Documentation is also there. Scroll some posts up.
I allow myself to talk about 2 bugs :
- Calibration bug of the display after restoration. (The screen occupies only 1/4 of the image when passing in 3840x2160).
- Sometimes, when watching a movie and pressing “return”, the box crashes.
Things that are going well :
- No problem with microSDXC SanDisk Extreme 128GB, A2, V30.
- (3840x2160 @ 60hz) -> The framerate of the GUI is around 25-35 FPS, it goes to 60 FPS only in the absence of covers. Compared to the old generation, we gain 5-10 FPS ; it’s better, it feels a lot ! But that remains insufficient. Between 40 and 60 FPS would be more satisfying. On the other hand, we gain a graphical interface much prettier! The pockets in native definition are absolutely beautiful!
- In UHD films, the temperature is on average 14 ° C lower than the Beelink GT1 @ S912. (35°C vs 49°C). The radiator is not there for nothing…
For the rest, for now, it rolls … We’ll see then.
Thank you very much for the work you do.
Bye.
The 1/4 screen is a problem from old guisettings.xml. Remove overscans and all works as a fresh install works too.
I don’t trust those FPS in debug overlay at all and I have information that in fact it is not reliable. I have done a lot of visual testing and I can not see the difference (without the FPS value) between 1080p60 or 4K60.
Frankly for me it is extremely obvious. Maybe you have activated a very powerful motion compensator ? The difference of 10 FPS in one direction or the other, jumps to my eyes.
Not sure what a motion compensator is. I use Estuary Mod v2 skin. Maybe on other fancy skins you see the difference. Also from FPS values they never go under 40 for me while scrolling movies.
Make a video please comparing both. Maybe I will see then.
FYI about crashing: We are hunting a kernel crash related to h264 decoder. So this might be the crash you talk about.
Montion compensator = “Motionflow”, “TruMotion”, “Auto Motion Plus”…
You’re at 40 FPS even when you scroll through hundreds of covers ? You are set to which display ? “Wall” for me. I will try to overclock a little GPU.
No I hate any motion settings it gives only soap opera effect. I scrolled through thousands of covers. LG OLED set to 4K60.
