Word of advise: should anyone have these SPDIF/Optical Out issues in the future (see quoted post), the solution is to update Beelink’s firmware.
Hi Gurus,
Does core elec work on Beelink GT-King Pro ?
Eero
Yes, just download the latest release and use dtb g12b_s922x_beelink_gt_king
(It does not have pro in its name, but it’s a multi-dtb that contains the dtb for both non-pro and -pro model)
Actually it contains dtb for s922x SoC revision A and B.
Can someone advise me how I could control the led diodes (skull eyes). Ideally using a python script (Kodi addon).
I am having issues with ceemmc on a Beelink GT-King WiFi6 Model.
here is the command line output:
i was able to get it installed by doing a dual boot install first, then changing to single boot
# CoreELEC #
# https://coreelec.org #
CoreELEC (official): 19.5-Matrix_rc2 (Amlogic-ng.arm)
CoreELEC:~ # ceemmc
Starting CoreELEC eMMC installation tool...
eMMC size: 0x000e67800000 [64GB]
No CoreELEC installation found on eMMC
Install in dual boot mode, CoreELEC and Android on eMMC
Use CoreELEC data from
Install in single boot mode, only CoreELEC on eMMC
[3] current used SD or USB device
[4] existing backup on current used SD or USB device
Please choose one option? [1/2/3/4]: 3
Free space of 'partition CE_FLASH': 512MB
Warning: Could not find 'dto' partition!
Free space of 'partition CE_STORAGE': 58388MB
Used space of '/flash': 235MB
Used space of '/storage': 4MB
There is enough free space on eMMC for installation!
Install CoreELEC on eMMC.
Continue? [y]: y
Moved 'env' from offset 0x00004d400000, size 0x000000800000 to offset 0x000000400000
Moved 'misc' from offset 0x000051400000, size 0x000000800000 to offset 0x000000c00000
Moved 'logo' from offset 0x00004e400000, size 0x000000800000 to offset 0x000001400000
Moved 'dtbo' from offset 0x000052400000, size 0x000000800000 to offset 0x000001c00000
Starting to format the new 'CE_STORAGE' partition...
mke2fs 1.45.7 (28-Jan-2021)
Discarding device blocks: done
Creating filesystem with 14947328 4k blocks and 3743744 inodes
Filesystem UUID: de0e496a-eea1-401a-ba3d-11255258bd9c
Superblock backups stored on blocks:
32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208,
4096000, 7962624, 11239424
Allocating group tables: done
Writing inode tables: done
Creating journal (65536 blocks): done
Writing superblocks and filesystem accounting information: done
Error opening file for writing '/dev/reserved'!
Failed to write the new partition table to eMMC!
** Update ** Solution is Here: https://discourse.coreelec.org/t/ceemmc-on-beelink-gt-king-fails/19029/5?u=spl147
anyone have an idea?
