oke i try the Omega version
The remote and Display config had that already working also the Power led
I got the Omega version now running on sd, but get a warning āMissing partition super on eMMCā
No media playback possible!
Never had it with the other versions
Reinstall android image back to emmc
I also have a āDā device
wifi works on version 21.0 NE ?
On 21 NE I can see networks but canāt connect. both 2.4 and 5
On 20.1 and 21 NG wifi works great without any problems
I never use WiFi, if you need me to check my box, I can do that for you.
Thanks, Iāll keep it in mind
Iāll try again myself later, and then Iāll write in the topic on WiFi problems ( Looking for users with no working WiFi or BT )
I just checked and there are NO WiFi connections listed. It does NOT even see any WiFi networks.
I had to make a new install using a different microSD card, because I turned off the Ethernet connection on my running box. There were no WiFi networks listed, so I disabled the Ethernet connection from the settings screen, instead of removing the ethernet cable. When I did a restart, it stayed on the CE screen forever. So, I had to do another install.
Lesson learned. We always learn from out mistakes.
Sorry for reopening the topic, but did you find a solution to this problem āMissing partition super on eMMCā? Or did you find a version of Coreelec that runs VC1 without getting bugs?
Here I can only run the versions below, which cannot play VC1, my tox3 is also s905x4 rev D
CoreELEC-Amlogic-ne.arm-20.2-Nexus-Generic.img.gz
CoreELEC-Amlogic-ng.arm-21.0-Omega_beta3-Generic.img.gz
The other versions of CoreElec that contain āaarch64ā in the name give the super partition error and it is not even possible to test.
Update with solution.
I have the same issue, 20.2 NE worked w/o issues, now I have the super eMMC, android is running on my TOX3, latest version⦠this might be it for now with the TOX3 ![]()
Update: Solved check my last posts
Are you experiencing subtitle blinking when VC-1 video playing? Subtitles flash. Same problem as the guy below! Iām on the CoreELEC-Amlogic-ne.aarch64-21.0-Omega_rc1 version.
Working with latest NE on my new TOX3 box. ![]()
Had vc1 issues esp on NE. Tried latest NE 21 nighty that came out today (20240404)
