9.2.4.2 Discussion
I m beginner, I Dnt know how to record log in Coreelec (kodi)? Kindly guide.
One picture shows a green screen but you already booted into a non green one. What’s the problem?
When I switch on my tv and x96 mini then first screen becomes green then I turn off android tv box and again switch on via remote then display becomes normal. I will post log as soon as possible.
Well we debugged that issue with green display but I guess you have a different problem. Logs help.
http://ix.io/2um5
Your kernel crashes. I think you should continue using 3.14. You GXL box is not 100% compatible with NG(4.9). GXL on 4.9 is still experimental.
Thanks Sir and very best regards for your kind Reply,I m upgrading my android box x905w to S905X3.
Hopefully it will work someday.
I can confirm that the green screen when I power on the box first and then the tv still there too on my nexbox a95x b7n ng builds
Please keep in mind that installing CE-ng on non-ng devices, even though implemented and reported to be working on a many different devices, is still considered an experimental feature and therefore not guaranteed to work “out of the box”.
Despite this, we can’t thank our developers enough for their continued support, dedication and effort to keep on implementing new devices and simultaneously assuring reverse compatibility, while making CE more reliable, more compatible and more stable with each release. It is no small feat to accomplish this, yet, they are doing it.
We also should not forget all the testers, who are volunteering a big chunk of their free time by testing nightly builds, and development releases, while frequently crashing their boxes. Thanks for being there.
And last, but not least, a thank you to our forum members for providing much needed feedback. Without your feedback, no progress would be possible, no bugs would be fixed, no new features implemented.
Let’s all keep up the good work, and remember that without you, your dedication, your feedback and your support, none of this would be possible.
Go Team CoreELEC!
Are you using Artwork Beef to download covers? In any event as I recall in Media settings you can choose the preferred language in the scraper.
Thank you for that answer. I am using the TMDB extension (already installed by default) and I have already set the language settings to FR but nothing to do, only one film remains in English, I do not understand why. I even tried to rename it but same problem…
I’m currently using a S905W box with 9.2.3 and have been following this thread while I wait for my S905X3 box to show up in the mail. I am still confused about one thing though; have the new non-ng builds also moved to the 4.9 kernel?
No, the non-ng builds are still at 3.14. But since 9.2.4 the ng builds can be used on some gxl devices (still an experimental feature).
I have a small problem with the TVheadend client on 9.2.4.2
If i change the Programs , i have ca. 1 sec a judder or freeze ,9.2.3 works fine
I test it on a ugoos am6 S922J and a H96 max S905X2
Has anyone the same Problem ?
Thanks for the clarification. I will upgrade mine to 9.2.4 without trepidation now!
Just upgraded my s905x android box with most recent coreelec build but have a few problems.
Cannot use yatse on android phone, it’s not recognized. Even trying to map manually the yatse informs no kodi build on the same network.
Cannot use Netflix addon (by castaignat) as I cannot put the username and password.
Do anyone encounter the same problems?
This was working flawlessly until upgrade.
Thanks!
Check the settings
Device: N2
I have a weird problem since the Update.
After i shut down CE everything’s fine and the N2 shows no led activity. As soon as i change the source from HDMI to TV the N2 starts up again by itself.
