After restart, Kodi notified about system error, this one is from kodi.log:
2021-04-20 16:36:39.229 T:4818 INFO : Python interpreter stopped
2021-04-20 16:36:39.558 T:4836 ERROR : EXCEPTION Thrown (PythonToCppException) : -->Python callbac
k/script returned the following error<–
- NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS!
Error Type: <class ‘locale.Error’>
Error Contents: unsupported locale setting
Traceback (most recent call last):
File “/usr/share/kodi/addons/service.coreelec.settings/se
rvice.py”, line 7, in
import oe
File “/home/portisch/CE/CoreELEC/build.CoreELEC-Amlogic-n
g.arm-19/install_pkg/CoreELEC-settings-cb1ebe7512797581ccacc0061e2d899d110c3566/usr/share/kodi/addons/service.
coreelec.settings/oe.py”, line 86, in
File “/usr/lib/python3.8/locale.py”, line 660, in getpref
erredencoding
File “/usr/lib/python3.8/locale.py”, line 608, in setloca
le
locale.Error: unsupported locale setting
–>End of Python script error report<–
2021-04-20 16:36:45.774 T:4884 INFO <general>: initializing python engine.
2021-04-20 16:52:21.909 T:4766 INFO <general>: Skipped 1 duplicate messages..
2021-04-20 16:52:21.909 T:4766 INFO <general>: Quitting due to POSIX signal
2021-04-20 16:52:21.954 T:4766 INFO <general>: Stopping player
2021-04-20 16:52:21.954 T:4766 INFO <general>: Storing total System Uptime
2021-04-20 16:52:21.955 T:4766 INFO <general>: Saving settings
2021-04-20 16:52:21.982 T:4766 INFO <general>: Saving skin settings
2021-04-20 16:52:21.994 T:4766 INFO <general>: Stopping all
Something about locale settings, from shell i am getting this output for locale command:
Previously, I was having installed few addons, new skin and I copied all configuration files in userdata/addons from old version of CoreELEC. Probably something there break database connection with MySQL, who knows…
hello. updated to rc2 and coreelec module drivers are gone. when i click on it it says no driver modules found. did something change in the dvb system?
Hi, remains the problem with version 19.1-Matrix_nightly_20210423, in Mecool K9 pro (s905x2 4Gb/32), after update wont boot, stuck in initial logo. When i´m back to 19.1-Matrix_nightly_20210420 or 19.1-Matrix_nightly_20210419 everything is ok.
If it still doesn’t boot, the only way would be to use UART.
You will need this CoreELEC Team SDIO Debug Board or open up the box and hook up to the UART pads. And you will need a UART to USB dongle in order to connect it to the PC.
If you have some issue then please describe it and upload logs. Also do clean install to confirm that your issue still present.
In most cases you have bad addon or bad config restored from old version.
P.S.: please also be more polite and specific.
Your first post looks very impolite and unfounded
Good evening, I updated to version 19.1 Matrix RC2 from version Leila 9.2.7 on my Odroid N2, only I no longer find in skin settings the ability to see or hide (Movie out in the cinema) is a small thing but I liked it a lot. Maybe it depends on some addon that doesn’t work anymore. Thanks.problema kodi.bmp (4.9 MB)
