Looking for users with no working WiFi or BT
I recently bought a TX3 mini that appears to have different hardware: both WIFI and BT are not working. I opened the box and found the following components:
Wifi chip: RTL8723AS
VFD chip: FD650B-S
Display: KY2453KG-302-1
Moreover, udevadm info /sys/bus/sdio/devices/* gives:
P: /devices/platform/d0070000.sdio/mmc_host/sdio/sdio:0001/sdio:0001:1
L: 0
E: DEVPATH=/devices/platform/d0070000.sdio/mmc_host/sdio/sdio:0001/sdio:0001:1
E: SDIO_CLASS=07
E: SDIO_ID=024C:8723
E: MODALIAS=sdio:c07v024Cd8723
E: SUBSYSTEM=sdio
Logs:
http://ix.io/2V5K
http://ix.io/2V5O
Is there any chance that the RTL8723AS will be supported? I noticed that CE does have a kernel module for the 8723BS.
X96 Mini here:
CoreELEC:~ # udevadm info /sys/bus/sdio/devices/*
L: 0
E: DRIVER=SSV6XXX_SDIO
E: SDIO_CLASS=07
E: SDIO_ID=3030:3030
E: MODALIAS=sdio:c07v3030d3030
E: SUBSYSTEM=sdio
X96 max + does not have Wi-Fi or Bluetooth
P: /devices/platform/ffe03000.sdio/mmc_host/sdio/sdio:0001/sdio:0001:1
L: 0
E: DEVPATH=/devices/platform/ffe03000.sdio/mmc_host/sdio/sdio:0001/sdio:0001:1
E: SDIO_CLASS=00
E: SDIO_ID=0271:050A
E: MODALIAS=sdio:c00v0271d050A
E: SUBSYSTEM=sdio
X96 MAX+
Both WiFi and BT not working. Seems like all info is the same as above.
L: 0
E: SDIO_CLASS=00
E: SUBSYSTEM=sdio
http://ix.io/2MMc
WiFi module used in X96 Max+ and X96 Air is Realtek RTL8188FTV. I made pull request on GitHub to be merged so it’s included in future builds.
If anyone wants to try for themselves, I made CE build today and it’s available for download here.
This don’t work for my X96 Max Plus Q2.
I don’t know, if this fits here, but I have a non working BT-dongle on N2:
You will be pleased to know that there is a way to enable it as discussed here.
Whether both the a and b varieties can be enabled within 1 build I do not know but there is at least a way of doing it.
I’m looking forward to an official ng-build for the N2 where the rtl8761b works :wink:
Got a X96 MAX plus Q2. No working WiFi or BT with sm1_s905x3_4g_1gbit. I asked the vendor and it seems like the Q2 version uses a different wifi chip.
L: 0
E: SDIO_CLASS=00
E: SUBSYSTEM=sdio
X96 MAX plus Q2 users:
Maybe it’s possible for one user to open the device and take pictures of the Wifi SoC/ACB?
With todays nightly (04-07) my asus wifi dongle is recognized, but i cant configure the network settings (only wired option available in CE settings).
Is it possible to use this type dongle now or make it work somehow?
Device is Odroid N2, C4.
Bus 001 Device 005: ID 0b05:17d1 ASUSTek Computer, Inc. AC51 802.11a/b/g/n/ac Wireless Adapter [Mediatek MT7610U]
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.01
  bDeviceClass            0
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  idVendor           0x0b05 ASUSTek Computer, Inc.
  idProduct          0x17d1 AC51 802.11a/b/g/n/ac Wireless Adapter [Mediatek MT7610U]
  bcdDevice            1.00
  iManufacturer           1 MediaTek
  iProduct                2 WiFi
  iSerial                 3 1.0
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x004a
    bNumInterfaces          1
    bConfigurationValue     1
    iConfiguration          0
    bmAttributes         0xa0
      (Bus Powered)
      Remote Wakeup
    MaxPower              160mA
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           8
      bInterfaceClass       255 Vendor Specific Class
      bInterfaceSubClass      2
      bInterfaceProtocol    255
      iInterface              0
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x84  EP 4 IN
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0200  1x 512 bytes
        bInterval               1
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x85  EP 5 IN
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               1
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x08  EP 8 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               1
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x04  EP 4 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               1
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x05  EP 5 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               1
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x06  EP 6 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               1
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x07  EP 7 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               1
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x09  EP 9 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               1
Binary Object Store Descriptor:
  bLength                 5
  bDescriptorType        15
  wTotalLength       0x000c
  bNumDeviceCaps          1
  USB 2.0 Extension Device Capability:
    bLength                 7
    bDescriptorType        16
    bDevCapabilityType      2
    bmAttributes   0x00000002
      HIRD Link Power Management (LPM) Supported
can't get debug descriptor: Resource temporarily unavailable
Device Status:     0x0000
  (Bus Powered)
This is a X96 MAX plus Q2, @Portisch.
There is a 1000Mb Ethernet RTL8211F, a Cdtech 4761743 radio module and two antennas.
Dear X96 MAX plus Q2 users. Please post the output of lsmod.
Hello!
I also have such a device (X96 Max+ “Q2”)
# lsmod
Module                  Size  Used by
meson_remote           61440  0
8021q                  36864  0
mali_kbase            499712  3
wireguard             139264  0
ip6_udp_tunnel         16384  1 wireguard
wifi_dummy             16384  0
amvdec_vp9            126976  0
amvdec_vc1             65536  0
amvdec_real            45056  0
amvdec_ports          200704  0
v4l2_common            16384  1 amvdec_ports
videobuf2_dma_contig    20480  1 amvdec_ports
videobuf2_memops       16384  1 videobuf2_dma_contig
v4l2_mem2mem           28672  1 amvdec_ports
videobuf2_v4l2         28672  2 amvdec_ports,v4l2_mem2mem
videobuf2_core         49152  3 amvdec_ports,v4l2_mem2mem,videobuf2_v4l2
amvdec_mpeg4           65536  0
amvdec_mpeg12         106496  0
amvdec_mmpeg4          40960  0
amvdec_mmpeg12         45056  0
amvdec_mmjpeg          32768  0
amvdec_mjpeg           40960  0
amvdec_mh264          163840  0
amvdec_h265           155648  0
amvdec_h264mvc         61440  0
amvdec_h264           147456  0
amvdec_mavs            49152  0
amvdec_avs             69632  0
amvdec_avs2           212992  0
stream_input          204800  12 amvdec_h265,amvdec_mavs,amvdec_mh264,amvdec_h264mvc,amvdec_ports,amvdec_real,amvdec_vp9,amvdec_h264,amvdec_avs2,amvdec_mpeg12,amvdec_avs,amvdec_mmpeg12
decoder_common        184320  18 amvdec_h265,amvdec_mavs,amvdec_mjpeg,amvdec_mh264,amvdec_mmpeg4,amvdec_h264mvc,amvdec_mmjpeg,amvdec_ports,amvdec_real,stream_input,amvdec_vp9,amvdec_h264,amvdec_avs2,amvdec_mpeg12,amvdec_avs,amvdec_vc1,amvdec_mmpeg12,amvdec_mpeg4
firmware               28672  18 amvdec_h265,amvdec_mavs,amvdec_mjpeg,amvdec_mh264,amvdec_mmpeg4,amvdec_h264mvc,amvdec_mmjpeg,decoder_common,amvdec_real,stream_input,amvdec_vp9,amvdec_h264,amvdec_avs2,amvdec_mpeg12,amvdec_avs,amvdec_vc1,amvdec_mmpeg12,amvdec_mpeg4
media_clock            45056  12 amvdec_h265,amvdec_mavs,amvdec_mh264,decoder_common,amvdec_ports,firmware,stream_input,amvdec_vp9,amvdec_h264,amvdec_avs2,amvdec_mpeg12,amvdec_avs
amlvideodri            24576  0
videobuf_res           16384  1 amlvideodri
videobuf_core          32768  2 amlvideodri,videobuf_res
videodev              286720  6 amlvideodri,v4l2_common,amvdec_ports,videobuf2_core,v4l2_mem2mem,videobuf2_v4l2
media                  40960  1 videodev
fbcon                  61440  0
bitblit                16384  1 fbcon
softcursor             16384  1 bitblit
font                   20480  1 fbcon
Mecool M8S Pro L
S912 3G
gxm_q201_3g
9.2.7
dmesg | paste
http://ix.io/2VA4
lsusb -v | paste
http://ix.io/2LV2
Bluetooth cannot find the device
本来9.2.7是可以用蓝牙的,还连接了蓝牙音箱。但是CoreELEC不支持红外遥控,于是我按网上找到资料在ssh中执行了以下命令:
systemctl stop kodi
systemctl stop eventlircd
ir-keytable -a /storage/.config/rc_maps.cfg -s rc0
systemctl start eventlircd
systemctl start kodi
然后蓝牙就不能找到设备了,服务里面能够启用蓝牙。烦请解决,谢谢
WiFi and bluetooth don’t work for me either. X96 MAX plus 4+64 (Q2?)
https://szoke.eu/egyebek/ssh_X96_Max_plus(4+64).txt
