Yes, I believe through advanced settings xml
Thanks, looks like this would do. Need to test it when I get homeâŠ
<loglevel>1</loglevel>
CE-22-20241213 and later versions, DTS: X audio cannot be directly downgraded to DTS, and only 6 channels are available for viewing player information
Hey Portisch, just to be sure, what do you mean with âThere is nothing for users to adjustâ ? Does it mean:
- disable the cache?
- use the default values of the cache? If yes, what are the default settings?
- does not matter what you choose, since the new experimental feature will ignore user settings related to cache anyway?
- something else?
ki pro s905d
latest nightly ng build
issue
endless buffering and image freezing or black screen only audio working
When change to another chanel or volume up or volume down on every chanel except 4k 50hz channels working perfectly
kodi.log (1.1 MB)
In âPlayer process infoâ is too long Czech translation âFormĂĄt obrazovĂ©ho boduâ so I cannot see wanted information. I was looking to latest KODI Nightly on my PC and this information is not there, so I assume it is Coreelec feature isnât it?
Yes, its not designed to so long translation. Need add to scroll for that value.
What box is that, cos empty cpu frequency?
@frodo19 Tanix X4 s905x4 4GB/32GB,dtb: sc2_s905x4_4g.
dmesg here: paste.coreelec.org/LiftingMeets
Ok, weird.
You are not the only one. It happens since the end of November both in NO and NE on my TOX3. So we have a â3 family 3 branches OSâ (to the developers probably time eating) vehicle with tons of features but no normal playback of simple material which seems one of the primary functions. I connected my old heavily modified Wetek Hub with antique Coreelec 9.2.8 and play the same x265 1080p files without any issue. Now I am just a âpower on - play file - power offâ end user that likes a lightweight OS having maximum possible performance of the hardware and nothing more but things are definitely not as they used to be. It feels that the software is catering for too many devices, setups, scenarios and every possible new technical doohdah. A comparison with Windows OS comes to mind.
You canât stop progress ![]()
In slovak language is shortly: âformĂĄt boduâ. Change czech translation to this slovak form. Problem after solved.
I am using NE on my TOX3 with no apparent issues atm.
Baz
Try some x265 1080p files. It is not always but quite often jerky playback is noticed. From USB it is worst.
The playback issues appeared after the November 26th nightly. I donât remember exactly but I think there was quite a lot of a/v sync related changes happening there so they are the probable reason. Itâs also likely that the issue is something which happens only on certain systems and setups. Basically it seems to be skipping frames when it doesnât need to. Iâll try the Nov 26th nightly on CE22-no later to confirm if it works properly - like it works on CE21-ne.
I will add some debug prints about the a/v sync in the next nightly to see what the case could be.
Tried 2 files, both OK, no jerky or frame skipping. On my Tox3 NE 20241231
Both files from my windows network with upnp.
âMobius.2013.1080p.BluRay.x265â and
âOne.False.Move.1992.1080p.BluRay.x265â
ki pro s905d
issue
on latest nightly build 20250102
interlaced media with 25 FPS not playing only freezing image
hereâs a sample 1080i-25-H264.mkv - Google Drive
kodi log
kodi.log (301.7 KB)
Try first on a clean install on spare media again.
after clean install the issue still present
kodi.log (682.1 KB)
Since 20250102 there is a extra A/V sync debug print included.
So if someone trigger âskippingâ of frames enable kodi debug logging and also component video + audio/video timing component!
Only Kodi.log is useful than.
