[S922X] Bee-link GT King
You can use it in your remote control mapping it.
You can watch kodi controls here
https://kodi.wiki/view/Keyboard_controls
For mapping, you can use keymap editor addon
My remote GT K is now unable to turn on. to turn on the GT K, I have to pull out the power button and insert the button. can anyone help?
Have you tried what is suggested a few posts above?
I do not understand how to use the Linux program. I’m actually blind about Linux.
that’s why the update will be fixed soon. I have been waiting … thanks
@suryo2908 it’s this post.
This can be done using windows. Just open windows explorer and put in the address bar:
      \\yourboxip
Then choose folder “configfiles” and copy the provided file to that location.
Reboot and try the button after this is done.
okay tomorrow I will try. btw, will this upcoming update include this problem? including dual boot?
As promised. Unfortunately, finding a working Samba Server for Android that supports SMB v2 was not as simple as I hoped. But today I found one that can be used in Win 10 explorer. For each transfer I have a screenshot at the start of the transfer, and one after over 70% of the transfer
I also added screen images from transfers to and from my Zotag box to contrast with the BeeLink box…
1 from PC to BeeLink Android EMMC
Copy%20from%20PC%20to%20BeeLink%20Android%20EMMC%20start .
Copy%20from%20PC%20to%20BeeLink%20Android%20EMMC%20during
2 from PC to BeeLink Android USBdisk
Copy%20from%20PC%20to%20BeeLink%20Android%20USBdisk%20start
Copy%20from%20PC%20to%20BeeLink%20Android%20USBdisk%20during
3 from PC to BeeLink CoreElec USBdisk
Copy%20from%20PC%20to%20BeeLink%20CoreElec%20start
Copy%20from%20PC%20to%20BeeLink%20CoreElec%20during
4 from PC to Zotac LibreElec USBdisk
Copy%20from%20PC%20to%20Zotac%20LibreElec%20start
Copy%20from%20PC%20to%20Zotac%20LibreElec%20during
5 from BeeLink Android EMMC to PC
Copy%20from%20BeeLink%20Android%20EMMC%20to%20PC%20start Copy%20from%20BeeLink%20Android%20EMMC%20to%20PC%20during
6 from BeeLink Android USBdisk to PC
Copy%20from%20BeeLink%20Android%20USBdisk%20to%20PC%20start
Copy%20from%20BeeLink%20Android%20USBdisk%20to%20PC%20during
7 from BeeLink CoreElec USBdisk to PC
Copy%20from%20BeeLink%20CoreElec%20to%20PC%20start
Copy%20from%20BeeLink%20CoreElec%20to%20PC%20during
8 from Zotac LibreElec USBdisk to PC
Copy%20from%20Zotac%20LibreElec%20to%20PC%20start
Copy%20from%20Zotac%20LibreElec%20to%20PC%20during
Hope this was useful for you. If you need more information, please let me know.
Baderks
Thank you for taking the time to do the tests.
Your results are similar to what I obtained. The note that was put in the release was because some team members had devices that had problems that made them almost unusable with ethernet. Beelink is addressing them. I (as you) obtain similar results in Android and CoreELEC so there’s only so much anything can be done. Obviously, the results with your Zotac are way better and that’s a question of hardware quality.
If the situation gets worse or changes in any way please feel free to post again.
With Support added for S905X2, S922X and A311D! posted, is the support for GTK considered equal to the N2?
I plan on buying a GTK, as far as I read here temps are no problem any more, but most important for me is the wifi. Is it working stable and fast enough for the advertised speed?
I want to exclusively run coreelec on it so I don’t care about dual boot, which seems to be the only thing not working currently. Are there any other known issues that I might have missed?
Thanks for the continued work on this project I really enjoy using it on my current Mini MXII III :+1:
BTK? If you meant the GT King, then it has not the same support as the N2 got.
Wifi and ethernet speed is far from stable, we have to send back some boxes to Beelink to investigate the issues.
Yes of course I meant the GT-King, sorry for the confusion.
I was under the impression that only Ethernet was having problems with stable speeds. Thanks for clarification that also wifi is currently affected.
I hope that Beelink is willing to debug/fix the issues.
I have downloaded version 722 and everything is running smoothly on my GT K. I hope dual boot will be available soon in the next version. thanks again to all the teams who have worked hard.
But you said that it works on 22 nightly?
No ideas, we sent a few boxes back to Beelink which had Ethernet and other issues. It will take a while for the boxes to reach Beelink, and for them to be tested.
Hi, any feedbackfrom bee-link on the ethernet issue ?
Nothing concrete yet. They told me they didn’t have any issues with Ethernet with the devices they got back from us. I sent them the model of the switch I’m using. Maybe it’s some sort of hardware compatibility issue, where it works with their specific network gear, but doesn’t work with some of the gear we have outside of China.
OK, anything to do with automatic negotiation of the Ethernet link ?
Automatic negotiation works fine.
finally the latest dual boot version is available … everything works normally and smoothly. thanks
I know how these chinese manufacturer works. Do not believe they go through any accurate testing, most probably for them it is enough that the link goes up and there is some traffic through it
