Ok ! I m a bit lost.
HDR is support no problem.
HDR10+ I need kernel 3.14 and GT1 do but not gt king ? Correct ?
And for Dolby vision ?
However, you do a really great job and the coreelec is awesome in many way !!!
Right now you need an older box (like the GT1) to watch HDR10+ movies.
There is hope that in the near future we will have HDR10+ support in ng CE too.
Dolby Vison is another problem, don’t expect support for it.
Ok it s clear now !
So I wait for the update !
And maybe in the future on an other box Dolby vision we will support
Thank you very much for the time you spend for me
Most probably they have changed some configuration on the PHY (eee maybe)?
It would be interesting to compare MII registers before and after
Slim chance, because Dolby Vision needs certification similar as Netflix official boxes. Since there are only a few NF certified boxes, and NF is much more needed than DV, figure out this future for DV yourself…
Btw, many new smart TVs have DV certification, so look in that direction for an update ![]()
Are there any other issues when comparing GT King running CE or is it basically the same as N2 now with fixed ethernet?
I know cooling is not ideal and it can only be run from SD but apart from that it should be equal to N2?
One stupid question : how to update Build number 905P0 in flash without losing booting the ability to boot into CE ? Last time i upgraded flash to 904P0, i couldn’t boot in CE so i had to go the the whole procedure of installing CE on SD.
I just made clean install of 905P0 this morning, installed Terminal emulator and executed command reboot update and current CE started from SD card.
You can find some video on YouTube for both of them to compare…
I don’t know about critical issues…
Yeah I know both devices. Was just wondering if they offer equal functionality in regards to CE or not.
You can also simply do the toothpick part of the process, you don’t have to reinstall CE.
It is the solution ! For sure ! I use an LG TV and when it is Dolby vision content I choose my TV instead of Kodi media player.
The inconvenient for me is the sound without dts hd ma but simple DTS.
In an other way I have to buy a new iMac 4K and I m pretty sure that will offer me all that I want.
For now, I think GT King with coreelec is an awesome way to play all my movie through my personal network.
I got to find some tips to “power on” remote control. But it works really fine for the price !
I have BT KING and I installed CoreELEC V9.2.0 stable and everything works fine, but when I turn off the Kodi with the Power off menu I can no longer power on the box.
Then I have to unplug the box to turn it on
I use original remote from GT King.
Or you can use:
And configure button here
Thank you,
can i do it like this:
This can be done using windows. Just open windows explorer and put in the address bar:
\\ yourboxip
Then select the “configfiles” folder and copy the provided file to that location.
Reboot and try the button after this is done.
Thank you CoreELEC team for your all great jobs.
just bought a GT-King on the way.
I want to know is this device support 4K HDR with Max CLL/FALL infoframe data passthrough when its use CoreELEC 9.2?
please tell me about this and thank you
I’ve been upgrading to the last version of the firmware (905) using the SDcard method without any issue. This firmware is supposed to solve ethernet issue on Android, but @boot2k3 apparently experienced that this solve his GBit issue too (on CE).
Also, there is a new SDK available:
https://beelink.oss-cn-hongkong.aliyuncs.com/TV%20box/GT-King/最新SDK/GT-K最新SDK.7z.001
https://beelink.oss-cn-hongkong.aliyuncs.com/TV%20box/GT-King/最新SDK/GT-K最新SDK.7z.002
https://beelink.oss-cn-hongkong.aliyuncs.com/TV%20box/GT-King/最新SDK/GT-K最新SDK.7z.003
https://beelink.oss-cn-hongkong.aliyuncs.com/TV%20box/GT-King/最新SDK/GT-K最新SDK.7z.004
https://beelink.oss-cn-hongkong.aliyuncs.com/TV%20box/GT-King/最新SDK/GT-K最新SDK.7z.005
https://beelink.oss-cn-hongkong.aliyuncs.com/TV%20box/GT-King/最新SDK/GT-K最新SDK.7z.006
https://beelink.oss-cn-hongkong.aliyuncs.com/TV%20box/GT-King/最新SDK/GT-K最新SDK.7z.007
It has been answered numerous times - yes.
I assume they tweaked something in the bootloader which gets Ethernet working right prior to CE taking over the boot process. My Ethernet was pretty much unusable at 1g, but now it works just fine.
thank you so much
