Support added for S905X2, S922X and A311D!
If you restored a backup from a S905X\S912 box, you need to read this post
Overscan is off in my TV
It’s in Kodi settings, but it’s possible there’s a DTB problem.
I am using S905X2_4g_1gbit DTB .How to disable overscan in kodi?
By reading the post I linked above.
where i find guisettings.xml?
No restored, it absolutely new setting only turned on dlna and play via network…
It works! You are a beast!!!
Edit: If a reboot, I need to put again the insmod command, that’s right? It uses the specified driver in the current “session” and after a reboot it uses again the system driver?
Thanks very much for the info. So I will download CoreELEC-Amlogic-ng.arm-9.1-nightly_20190722-Generic.img.gz
I understand the device tree is on the image and I just copy and paste the correct one. Will give it a try.
Don’t forget to rename the copied dtb to dtb.img in the root
Warning developers!
I haz dtb from X96 Max Android Pie 9.0 If you needs I can upload it
If I try to change kodi gui resolution from 1920x1080p to 3840x2160p I got the same coloured stripes as per my post # 137 and, after few seconds the gui resolution falls back to 1920x1080p
We know what the problem is, and will work on it to resolve.
thank you. at least i know now that my box isn’t fault.
We are not 100% sure, but we’ll look into it.
@Alestilohomer No I only asked you to do this for testing purposes, I will make sure the driver is included in tomorrows nightly so you don’t need to do anything.
Hello there. Can anybody recommend me a android box for CE? Basically just looking for dual WiFi.
I have exactly the same issue with T95Q. Below are the additional issues I noticed.
  1. unable to play 4k videos. It splits the screen into 8 parts. Top 4 parts display file browser and the bottom 4 parts play the movie. I cannot get out of the screen. Ended up pulling the plug.
  2. Remote doesn’t work. I had to connect an rf keyboard and mouse.
I dont know about your remote but I am sure that someone here will help you.
The devs are working on the 4k issue and will sort it out for sure.
Other users have working remote so the function itself is not broken.
You can follow How to configure IR remote control to setup yours.
