I am having the same issue with Termius. Opens then closes instantly.
Good, there was a āupdateā of the auto color depth patch. Before it was max 10bits, now it goes up to 12bits. So it depends on used hardware setup if 12bits are really supported and working 100%.
Try the fix given given by vpeter in his response to me. Worked perfectly once I ran the command from another linux device on my network.
If you donāt have another linux device on the network they maybe try live booting linux from installation media.
That fixed it. Thanks.
The Kodi log is full of errors about not supported repository.zachmorris format. It comes from the built-in Kodi game repository which cannot be removed or disabled. Not sure if this should be reported here or to Kodi.
Try nightly where repo was removed.
Hi !
I updated 19.5 rc3 to Nexus rc1.
Odroid N2+
When I start a video I have ā100% cachedā which stays in the middle of the screen.
Has anyone had this problem?
Thank you ![]()
Start with fresh install when switch major versions. Or at least try first with separate sd card/usb stick.
On my Ugoos AM6B PLUS, there is no Analog (Av OUT socket) PCM audio. All other Audio outputs work fine.
The same issue was there in CE 19:
IS this something that can be fixed in the next CE release?
Thanks so much ![]()
no, for screenshots you will need to enable double buffer in kernel. for h265, vp9 and av1.
On a semi-related note, the Kodi xbmc.RenderCapture interface no longer works in CE20, was largely working fine in CE19, including latest nightlies, with double write enabled.
Not sure if it has anything to do with this?
Playback stalls and stops after sometime as cache runs out. Odroid N2+ with LAN (1gb connection), same thing happens with wifi albeit faster.
Dmesg log:
http://ix.io/4kYO
Debug log
Anyone got addon Speed Tester working from Kodi repo?
Problem
I want to step from CoreELEC 9.28 non-ng to CoreELEC 20.0-Nexus_rc2-ng. My DVB-T2-HD is not fully supported natively. Other drivers had to be installed. The workaround for that (1 2), that worked with 9.28 and 19.5-ng is not working. DVB driver module switcher (CoreELEC Module Drivers) crashes.
The log .kodi/temp/kodi.log reads
2023-01-14 20:11:16.695 T:3696 info <general>: CActiveAESink::OpenSink - initialize sink
2023-01-14 20:11:16.695 T:3696 info <general>: CAESinkALSA::Initialize - Attempting to open device "default"
2023-01-14 20:11:16.702 T:3696 info <general>: CAESinkALSA::Initialize - Opened device "default"
2023-01-14 20:11:16.703 T:3696 info <general>: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
2023-01-14 20:11:16.703 T:3696 info <general>: CAESinkALSA::InitializeHW - Using data format AE_FMT_S24NE4
2023-01-14 20:11:56.792 T:3696 info <general>: CActiveAESink::OpenSink - initialize sink
2023-01-14 20:11:56.792 T:3696 info <general>: CAESinkALSA::Initialize - Attempting to open device "default"
2023-01-14 20:11:56.798 T:3696 info <general>: CAESinkALSA::Initialize - Opened device "default"
2023-01-14 20:11:56.799 T:3696 info <general>: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
2023-01-14 20:11:56.799 T:3696 info <general>: CAESinkALSA::InitializeHW - Using data format AE_FMT_S24NE4
2023-01-14 20:12:12.876 T:4254 error <general>: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
- NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS!
Error Type: <class 'AttributeError'>
Error Contents: module 'xbmc' has no attribute 'translatePath'
Traceback (most recent call last):
File "/storage/.kodi/addons/script.program.driverselect/default.py", line 1, in <module>
from resources.lib.tools import *
File "/storage/.kodi/addons/script.program.driverselect/resources/lib/tools.py", line 10, in <module>
PROFILE = Blockquotexbmc.translatePath(xbmcaddon.Addon().getAddonInfo('profile'))
AttributeError: module 'xbmc' has no attribute 'translatePath'
-->End of Python script error report<--
Full log can be found here.
This is a Z69 S905X 3GB/32GB box with a HanfTek Astrometa DVB-T/T2/C FM & DAB receiver [RTL2832P]. When using DVB drivers from latest kernel, the DVB-T2-HD device was functional with tvheadend in 9.2.8 and 19.5-ng. However with 20 the Module drivers selector seems to be broken.
Steps to Reproduce
- Fresh Install of CoreElec 20.0-Nexus_rc-ng on SD Card (copy
gxl_p212_3g.dtsas device tree) - add
remote.confto.config/ - Finish installation
- Install Addons
CoreELEC Add-ons > Dienste/Services > DVB drivers for TBS
CoreELEC Add-ons > Dienste/Services > DVB from the latest kernel
CoreELEC Add-ons > Program-Addons > CoreELEC Module Drivers - Run CoreELEC Module Drivers to select drivers via GUI
Addons > CoreELEC Module Drivers - Result:
CoreELEC Module Drivers Error, see picture above. - Expected Result: Selection Dialogue appearing as in previous versions
Thank you very much for your time
krelmatrix
Manually update the addon script.program.driverselect to 0.1.6.1.1. There was a old version located confused the update system.
Yes
Only in Matrix though
Have tried in Nexus ng and ne
Just hangsā¦
Maybe has not migrated to Nexus yet?
CPU Benchmark works in Nexus.
Happy Testing
Hi Portisch,
Thank you for your immediate reply. I tried to install version 0.1.6.1.1 from here over 0.1.6.1.100 from repository and got an error āDependencies of xbmc.python in Version 2.25.0 could not resolvedā:
2023-01-15 08:49:56.654 T:3674 info <general>: Loading skin file: FileBrowser.xml, load type: KEEP_IN_MEMORY
2023-01-15 08:50:00.413 T:3940 error <general>: CAddonInstallJob[script.program.driverselect]: Die Abh..ngigkeit auf xbmc.python in Version 2.25.0 konnte nicht aufgel..st werden.
2023-01-15 08:50:25.187 T:3703 info <general>: CActiveAESink::OpenSink - initialize sink
See full log
Thank you very much
krelmatrix
