I guess they were talking about the @doppingkoala builds on Reddit.
Latest build is here:
Are you using HS400 speed mode from core elec settings?
Hs400 on u22xj is risky ! I tried two times on my u22xj in past and after tvbox was always in bootloop. And i repaired only trough backup.
Yes, not works with Minix.
2 posts were merged into an existing topic: Help, support CPM build
What’s the real world speed difference between HS200 and HS400 on the AM6+?
What are read speeds in both modes?
CoreELEC:~ # hdparm -Tt /dev/cache
I don’t have my device with me but if I remember right
HS200 = 150-160 MB/s
HS400 = 190-200 MB/s
Has anyone audio/video sync issues with lastest stable build? I´m not quite sure but a friend of mine lately said that there is a slight desync… (DV-movie, A/V receiver lip sync disabled)…
Are there any testpatterns to prove him right?
there’s a topic regarding the issue:
can someone think of an addon (I installed a lot as I was new to all that some month ago) or a setting that is preventing my ugoos amb6+ ce kodi to show dts x icons (file names includes dts x)?
a kodi installation on my android tab for testing with the same skin but no additional addons is showing dts x icons
playback of dts x all perfect, as the Pic quality and everything else ![]()
Hi all,
just a quick question, I have been using coreelec kodi installed on an external ssd drive and would like to know if i install the coreelec kodi to the internal would it be much faster at booting and also any GUI speedups accessing the library that is saved on the local drive be any faster.
as i am thinkig of doing this but if its no benifit and know if its worth the bother .
thanks all
no help on this thanks
I do not test this particular box
However many others.
It will be noticeably faster on internal
Access library also should be.
The difference will be in storage/ going from ssd to internal???
32 gig on this box?
And you will free up the USB Port were using.
Test and Try!!!
Can always go back to external
Hi, I’m sure this has been asked so many times, but couldn’t find a direct answer. Been using Kodi with a specific addon on an Xbox Series X (I Know, right) since last year with an LG C3. I have to settle with just HDR content since the Xbox is unable to use DV on Kodi.
Would really like to be able to get DV content in the highest quality but I’m unsure which device to go for. I’m only looking to stream 4k DV content using kodi add ons
From what I understand the shield pro 2019 does display DV but not in highest quality. I believe the Ugoos AM6B+ is king when it comes to DV media players, is the set up easy?
If I’m only looking to Stream 4k Dolby vision content through Kodi add ons, is the AM6B+ overkill for my needs or something I should definitely get? And if so, what is the set up process in Layman’s terms.
Open to other suggestions and any help much appreciated, thanks!
Not sure what kind of addons you are talking about? For legal addons to display 4K DV you will need to run Kodi on an Android device with Widevine L1 security level. Otherwise you will be limited to max 1080p AFAIK.
Not-so-legal addons are not allowed to be discussed here.
The Ugoos is more suitable to playing your local files in 4K DV (including P7 FEL).
Any of these boxes in this thread should work:
But highly recommend Am6b+ for its DV FEL maturity and all around performance on remuxes.
cheers is there a way to get the image from the sdd to the internal so it will just boot ?
thanks
SSH into the device via it’s IP address and then use the cemmc command as per the installation guide
