Although the CoreELEC otherwise runs great, my Ugoos X4Q Extra unfortunately has a few small errors, reproducible. But I don’t know, if that could be due to my box or if it is due to CoreELEC.
The box was previously updated to the latest Android 1.2.4. (But it was also tried with the original Android version 1.1.8, with the same result. So it can’t be due to an “incorrect” installation of Android.)
I tried it with two micro SD cards:
Installation 1:
Sandisk, A1, Class10, 16 GB: CoreELEC-Amlogic-ng.arm-21.1.1-Omega_nightly_20241206-Generic.img.gz + subsequent update in the device via the update function to Omega 21.2
Installation 2:
Sandisk, A1, Class10, 64 GB (purchased brand new): CoreELEC-Amlogic-ng.arm-21.2-Omega-Generic.img.gz
The flashing was triggered using the toothpick method.
Device tree used: sc2_s905x4_ugoos_x4.dtb → renamed to dtb.img and copied to the root directory of coreeelec.
Installation 2 in particular is a pure test installation in which I have not changed anything.
I simply approved the few queries at the beginning (system language, SAMBA, etc.) and then switched on logging and then shut down the system.
By the way: Immediately after installation (the box was previously without power and was then flashed using a toothpick and switching on the power) the network connection was there and activated!).
Error description:
- Error:
After the first boot, AFTER THE BOX HAS BEEN DISCONNECTED FROM THE POWER, the Ethernet connection is deactivated and cannot be activated. Only after another reboot (without disconnecting it from the power) is the Ethernet connection there and activated. - Error:
After the first boot, AFTER THE BOX HAS BEEN DISCONNECTED FROM THE POWER, it won’t shut down, but instead reboots. It doesn’t matter whether I turn the box off with the corresponding button on a USB Bluetooth remote control or the original remote control or via the menu (-> Shut down). - Error:
The LED light on the box remains white after shutting down. If you look closely, you can see that the white has a very slight green tint, but you have to look closely, ideally watching the transition when it’s turned off. If you don’t have a direct before/after comparison, it just looks white and you think the box is still on!
When you start the box, however, you can see how the LED briefly turns red, then green (real green!) and then white. The LED can therefore display both a real red and a real green.
On Android, it also turns red in standby and goes out completely when shutting down. Couldn’t you set it up like that under CoreELEC? Either red or, best of all, just off completely when you shut down the box.
I activated debug logging during installation 2, as described here:
Then I shut down the system and unplugged the box for a few seconds. Then plugged it back in.
Now I wanted to upload the debug log (Settings > CoreELEC > System > Submit Log > Upload latest Kodi log).
But not entirely surprisingly, an error message came up:
Failed to paste log files, try again.
As described, the box had no Ethernet connection after power was turned off!
Now I shut down the box to generate the second error (reboot instead of shutdown).
As expected, this reboot actually happened (although I actually just wanted to turn the box off) and then I tried uploading the debug log again and this time it worked:
https://paste.coreelec.org/RalphPickle
I wonder if the error with the missing Ethernet connection before the last reboot can still be seen in this log?
But I also found two log files in storage/.kodi/temp (or something similar) that I will also try to attach here (I am not shown whether the upload was successful or whether it is attached.).
One of them is called kodi.old.log, which could possibly be the first log file when I had no Ethernet after the first reboot (after power off).
kodi.log (104,6 KB)
kodi.old.log (121,9 KB)
